30mA, generally (though 10mA RCD outlets are available for medical applications). At least 2 RCDs are required in an Australian home, and each RCD may feed a maximum of 3 subcircuits.
Normally we use the Multiple Earthed Neutral system (similar to Protective Multiple Earthing in the UK), which does not require a main RCD as used with TT systems.
