Is there any definitive code definition on:
- a) How high the weatherhead and point-of-attachment needs to be above grade?
- b) Whether the weatherhead is required to be higher than the point-of-attachment?
- Whether the height might be to the bottom of the drip loop (which should be lower than a) or b), or the actual attachment point(s)?
Also, I am assuming the height would be measured as a direct vertical drop to the ground from any of those points but if it's some sort of "grade within xx feet of vertical drop", I'd need to know that.
I've done some searching and there's lot of discussion out there of all three points, and suggestions that it's power company specific, and that it's state specific, and that it's code specific, but I can't find any hard answers.
FWIW, A survey of local installs (Massachusetts) generally finds the weatherhead lower that the POA, but every thing is old here (old code) and everything new is two tall stories high. Overall height seems to be more of "close to the corner the most convenient corner of the house for the power company to string the wire to" but it's hard to tell.
Thanks,
