About you can do is measure the voltage drop across each contact with it operated under load. You should be very close to zero volts. Checking for ohms may be an indicator but it does not prove it actually is carrying the load.
I have taken things like this apart in an emergency and tried to fix them but it is always a temporary fix if it works. Get a new one coming.
