Yep, I'm going to have to try one of the above mentioned. I've used the type with the 2 funnels before on small 16/3 cord, but not on UF cable. I was looking at one at the supply house the other day, and wasn't sure it would work for big 10/3 UF cable. I went with the schrink tube again. Still don't like it using a blow torch. I guess I need to buy me a good heat gun. The blow torch tends to get too hot, and then if I miss a lick, I hit the wire, and they ain't good. ....
