Replace the switch. If you still have problems,probably time to get some help.
A big problem with Janitrol is every jackleg and lowlife can buy it. They are not too picky about dealers. So the equipment often ends up mis-applied and/or crappily installed. Then the equipment is unfairly blamed for problems.
