I don't need more than 100VA ... light weight so I can carry around with the netbook I power up with it where I need to when the battery runs low. This is so I don't have that 120 Hz vibration feeling on the surface in front of the keyboard around the mousepad due to the fact that the unbalanced power the 120V normally has will be capacitively coupled across the power adapter and raise the voltage level of the DC side by 60 phantom volts relative to ground.
It looks like that catalog does have something I might be able to use, if I can find a suitable enclosure for it to mount a receptacle and either grommet a cord or mount an inlet.
