To answer the question, I would say no, you need to derate. The roof top is specifically set aside as needing special attention.
I am still not sure I actually understand this "heat sinking" thing anyway. They say I can run 10 feet by a hot furnace without a problem but heat sinking does not happen in Romex running an inch and a half through insulation.
