Has anyone actually failed a job for not using Carlon cement?
What if you had Carlon pipe and Cantex fittings. Would you use 2 different cans of cement? (one on each side)
My real question was more directed to cleaning dirty pipe. Do you think that is a good idea? A plumber/plumbing inspector will tell you that the primer makes that joint several times stronger, particularly if the pipe is dirty.
BTW maybe the lack of primer is why Carflex is not listed in a cemented fitting. I guarantee you, if you prime it and glue it, the fitting will pull out of the box before the joint fails.
