wacked, the thing to remember with the FSR qualification is that relates to permits. So your B FSR means you can pull a permit and be responsible for work of any ampacity up to 750 volts. Even with no FSR qualification you can still perform electrical work to the limits of your TQ, you just cant pull the permit. So in Alberta you should be able to perform electrical work to the limit of your TQ without their equivalent of an FSR qualification. If you want to become a contractor then that is a different story. Contact Alberta Municipal Affairs, here is the link to their Master Electrician qualification.
http://www.municipalaffairs.alberta...ical/Notice-MasterElectricianProgram.pdf
