forgot to add, use a coathanger with a sharpened end. drill throught the flor or ceiling right next to the wall. this will give you a location for drilling your wiring hole from the attic or basement without guessing, and will leave a very tiny hole which you can fill with drywall mud if it's ceiling. and if it's floor you won't even see the hole later.
