I am on the same page as Rewire make sure you get contract for replacing the bulbs plus any other related items to the luminaires and expect after hours changing espcally with mall or large parking lot luminaires it the best to do it during nite time when the parking lot is empty or very few vechiles parking on the lot so you don't have to really have to make a fancy move to get to the lumiaire ditto with inside as well just prepare to get couple diffrent lifts in case they have light floor load rating.
And make sure you have couple case of common bulb sizes plus ballast as need to be used on site.
Anything more than simple repair you will have to draw up new contract with that situation.
{ that happend to me more than once }
Merci,Marc
Last edited by frenchelectrican; 02/13/10 10:51 PM. Reason: fix the spelling for one member { opps }
