No, it is never OK to place more than one wire in a 66 block terminal. They have a "V" shaped throat, so once the first wire is pushed into it, another wire on top will not be held securely.
The only proper way is to loop a jumper between two rows of clips so that there are more termination points made available.
---Ed---
"But the guy at Home Depot said it would work."
