Forget that stuff, use superconducting wire. #24 or #22 should be plenety.
Ernie- What you do is cut off several strands so the wire will fit in the breaker, but do it on the back side so the inspector don't see it. ha ha ha
Hahahaha, you know what? I actually LIKE this solution! Simple, elegant, and eliminates points of failure.
