This would mean much larger transformers. For example if the data center loads needed 375 kVA in an isolation transformer, a 50 kVA 240:32 transformer would do where its secondary were supplying 1/7.5 of the voltage.
Have you ever tried to find a 50kVA unit with a 32V output? Talk about special equipment.
