OK, Reason I suggested what I did (even though Merlin had the better idea of using a tee), is during my training, I was always told to get the sensor probe as close as possible to the sensed medium,as it makes the readings that more accurate. Actually in it, is about as close as you can get, however that should not be beyond the expertise of most electricians as far as keeping things from leaking goes.
