Old work can be a little time consuming sometimes. You tend to find ways with experience that moves you through some situations. I would think the best way to start out is time and material. Some electricians wont do it any other way. Giving a flat rate can hurt you. Depends on the situation. If it's just an outlet, you could go flat rate, and increase the price per floor.
