Jim, I think you nailed it with the receptacle clearances for indoors v. outdoors. But as for the luminaires issue, all one has to do is put GFCI protection on the circuit and use a non-metallic trim/or isolated metal parts and you can locate the fixture at any height you want. Even below 7'-6''.
