I'm quite sure that this will work using 3-wire and a double pole GFCI breaker and splitting the hot on each receptacle, but I want to be 100% sure. It makes for a good argument.
Absolutely, it will work with (1) double pole breaker and 3 wires.
Absolutely, it will not work if (2) single pole breakers are used unless 4 wires run.
