In order to comply with 250.21(B), I need a ground detector. All I've found so far is one made by Cutler Hammer (way too expensive at about $2000) and a detector that uses lights (haven't priced it yet). I'd really like to have something with a set of relay contacts that I could hook to a bell or horn in order to get some attention when the first ground fault occurs.
System voltage will be 480 volts.
Anyone know of a product that will help me?
Few things are harder to put up with than the annoyance of a good example.
