60sn is what I like but I also follow the "mechanical connection" rule. You are just flowing solder over the connection that is already secure, allowing it to wick into the joint.
If you are one of those folks who "build up" the solder connection 40/60 might be better for you since you can work the liquid front. Stained glass folks like that.
