Has anyone had a chance to play with these yet? I did yesterday with some P&S ones and found out they really don't work as I expected. If you put an object in one side, you can't push it in far enough to touch the contact as expected. However if you hold the object in the first side and insert a second object in the other side, the shutters open and both objects will be able to touch the contacts. We also tried plugging some cords in and had no problem with the cords on a couple of power tools, but the cord end on an imported portable electric heater could not be inserted into the receptacle. It looked like the blades on that plug were thicker than the ones on the other plugs. This could be a big issue if the homeowner cannot plug things in. Don
