You can offer all the advice, from EC's many years of making, serious mistakes, and the true dreamers, will disgard all the advice, and dive in head first.
They are sure your advice is all wrong, and they have seen many guys, that started at the bottom, and made it big, but if you ask them, did they take the time to check out these claims of, I made it from nothing stories, there is no response, as you noted, most guys don't even bother to check the area, to see if there is a need for another business.
Check the county records, to see how bad things may really be, someone will always come along, and claim they made it, without plans, and are making big money.
My bet is, if you had access to their records, you would most likely find, they are not what they claim. These are the guys that talk louder, until someone listens, the ones that are really making it are usually, not found on the forums, they are both private, and keep their business matters, to themself, your better off searching out a truly secessful business owner, and letting them mentor you thru the learning process.
