The wires go out with the line sets into a patio slab. The owner thinks they go to the pool shed. this was all 1 110v circuit with the following loads. pool light, pool motor, master bedroom receptacles, small workroom lights and receptacle, pool shed light?, The water heater had a flying splice on the wall opposite(not shown) 10/2 Rx to 12/2 Rx then the connection as u see them no disconnect. There was also a feed from another circuit coming in that was opposite phase and this kept tripping the cb. That was the reason they called he couldn't figure out why it was tripping. The pool light never worked fortunatly.
