Removing the light from the niche is not considered "servicing". They just mean you can put it on the deck to take it apart for "servicing" by a dry electrician. The actual removal of a pool light always involved getting in the water since they need to be 18" below the water surface which puts the screw more than two feet down. (unless your helper is a center for the Celtics in his spare time).
