My son says his house lights blink when a washing machine cycles and I suspect a loose connection or bad switching device. What is the best way to check a circuit breaker for deterioration? I've heard you can check voltage drop from line side-to-load side of a breaker using the millivolt scale. Is this a good check? Any wisdom from experience will be most appreciated.
