as much as I dislike the petty nattering of home inspectors, at least if a HI took a look at this it'd probably get a real EC in there to clean this mess up, a lot of the problems here are cosmetic, debatable, or violations dependent on local codes, but there are some genuine safety issues I can see, mainly at that hacked up meter/disco combo.
that panel looks like a Siemens, which is about the cheapest of the cheap, although the screw and the way the verbiage is printed on some of those breakers makes them look like SQD, (which the panel is obviously not)
I just don't like it
-Will
