Are you using 120V 15A receptacles? You should never plug more than 1500W worth of anything into a single outlet, but you should be able to safely plug 1500W worth into a single outlet without creating a fire hazard.
Huh?
Why 1500 Watts? Why not 1800, why not 1440 Watts? Is this figure just pulled out of thin air?
(BTW, Tex is listed in his profile as an Electrical Engineer.)
