The first thing to remember is that the NEC stops where the PoCo takes over. In most instances, we can consider the meter as this point.
So ... that would be six disconnects after each meter.
These are not to be confused with customer owned meters that there night be on each space.
If the meters at each pedestal are, in fact, PoCo meters, then the NEC does not apply to whatever feeds those meters.
