Hey Trollog
You mentioned that you changed the start cap and then the motor started and ran fine for 2 min. before the new cap got smoked again.
If the centrifugal switch was fused the new cap would go up in smoke. Then when you tried to start it again it would be doing what you describe simply because the new start cap is smoked.
Just a thought but might be worth exploring.
