I agree on the surge protection.
I had lightning hit the air terminal above my weather station the other day. The only thing I lost was the serial port on the laptop that the weather station connects to.
I am still not sure what is wrong with it, I can run the diagnostics but it won't connect.
I did have to reboot a couple other PCs that were on, my cable box has a new 60hz bar running through the picture and my CMOS light controller needed a brain transplant (power on reset) but everything else was OK.
I am going to replace my panel protector although the light says it is still good.
All things considered I think the money I spent on the lightning rod system was well spent, (mostly copper cost) and good surge protection is mandatory.
