normally the single pole thermosat dont useally have off indent or marking but to make sure you have off postion most common is the double pole thermosast do have off marking expect few specal thermosast they used without a marking because of " frezze guard " it will come on at 35-40 degrees range i am not sure excat number there
Merci, Marc
