Jeff, Your description appears to be in compliance with the Code. Three wire to the sub panel and seperated grd. & Neutrals. Using conduit for the ground path from the service disconnect to the distribution panel is a design consideration, but does comply. Ask the AHJ about the neutral and his reasoning. We all want to know. Alan--
