1 members (Scott35),
417
guests, and
27
robots. |
Key:
Admin,
Global Mod,
Mod
There is apparently many ideas on how to to this, but the current code is that you run a four feeder and use an insulated ground wire once you leave the main building and go into the ground. And you separate the ground bar and neutral. In our area the the AHJ will tell you to remove the ground rod, paralell path.
Entire Thread
To ground, or not to ground,... that,..is my qwery
Attic Rat
05/04/07 01:22 AM
Re: To ground, or not to ground,... that,..is my q
Gregtaylor
05/04/07 03:19 AM
renosteinke
05/04/07 03:32 AM
Re: To ground, or not to ground,... that,..is my qwery
Gregtaylor
05/04/07 04:31 AM
gfretwell
05/04/07 04:40 AM
Niko
05/04/07 04:59 AM
jdo1942
05/04/07 10:10 AM
Fred
05/04/07 10:37 AM
RonS
05/04/07 10:43 AM
yanici
05/04/07 01:51 PM
resqcapt19
05/05/07 02:38 PM
CDS
Nicholson Ga
