These pics were provided by Ian, "theelectrickid." I am told that this is a typical GEC arrangement from "Leavitt town" homes of the 60's.
First, a bare aluminum wire exits the panel:
![[Linked Image]](https://www.electrical-contractor.net/forum/RS/Leavitton_ECG_1.jpg)
Then, under the kitchen sink, the wire terminates at a cold water pipe:
![[Linked Image]](https://www.electrical-contractor.net/forum/RS/Levitton_EGC_2.jpg)
As I understand it, there is no ground rod.
I have a few issues with this method. Perhaps the first one is suggested by the corroded clamp on the pipe, above the one being used .... aluminum wire + brass connector/ pipe = corrosion.
Any thoughts?
