It all depends on your state's particular laws and precedents. It also depends a lot on how your company is organized and the name listed on the license. If it is a corporation or LLC, then in TN the company would liable and not you personally, as the license is issued in the company name no matter who takes the test. If the license is in your personal name, then there is probably a good chance that you could be liable.
The best answer is for you to consult with a qualified attorney in your local jurisdiction. If it turns out the you are personally liable, then your attorney could advise you on what to do next.
Kevin
