My rental last month of a trencher was $145/day. They set the cut for 6". If it had been flat a 65' run would have taken 30 minutes.
(The area tilted, and had obstructions, so it took a little longer to rassle with the machine).
Don't forget to call JULIE
(or whatever you underground utility locatins service is called near you)
[This message has been edited by DougW (edited 06-03-2005).]
