Main CB's in 3R disco's when mounted directly below the meterbase (and using SE cable) tend to go out frequently.
Other than that, I'd have to agree... Breakers get a bad rap for being "the problem child" and are usually just doing their job!
I try to explain, that in most (residential) situations, a tripping breaker isn't bad, but a breaker that won't come on at all may be bad (but more likely the circuit will have a dead short {bolted fault})... If it crunches when turining it on or off, it is probably bad.
