Just because the receptacles are 2 prong doesn't necessarily mean that a ground is not available inside the outlet box. Have an electrician check them out. If a ground is available and is of sufficient length, you could probably have them replaced for $15-25.00 each(depending on how many) plus a minimum standard service fee.
