Went back over there and took another look.
At the rear of the house, there is a #6 bare wire connecting the two halves. Then a take off that disappears in the bottom.
Inside, what I believe to be the same wire, it is tied to the ground bar.
There are two bars, one each side, connected by another bar. Which, to me, means it is all tied together.
This part is factory installed.
