Do electrons vibrate/oscillate with a voltage applied?
I imagine they would shimmy quite a lot, when they are under pressure - especially since they would be bursting towards the outermost areas of a Conductor - vs - slipping in and out of various "Bands" and doing other neat Subatomic stuff
They can't flow without a path, but can they sit there and oscillate without a complete path?
Even if there isn't a "Physical" closed Circuit, if Conductors are connected to a Power Source
(something with an ample supply of free Electrons + holes for them to fall into - thus having a Potential Difference between the ends of the source),
there will still be currents flowing in the conductors.
This is known as "Line / Circuit Charging", and must take place on any AC or DC Power System.
The charging is Capacitive, in Parallel to the conductors connected to the power supply, and in series through the same conductors (via many methods - including skin effect).
The charge levels will constantly be changing, due to System Voltage, changes of the Proximity State (like if someone walks by the conductors, or something moves), and the normal leakage between the "Capacitive Plates" so to say (like how a typical Capacitor will leak a stored charge).
I would imagine all this shuffling around of charge states, would certainly gyrate Electrons (and holes), much like Elvis gyrated on stage!
Viewing a "Stable" Atomic model - something with a few layers, such as an Iron Atom, the Electrons orbiting the Kernel will be "Orbiting" the Kernel (AKA "Nucleus"), much like Planets orbit the Sun - or Satellites orbit the Planets.
As they orbit the Kernel, they are also rotating - just like Planets and Satellites rotate.
Since they are rotating and falling around the Kernel - along with how they are influenced by other Atoms / Molecules / Forces, and they may move into a lower power level valence, but are at the same time bound to orbit / fall around the Kernel at a certain power level - AND, there is a "Magnetic-ish" interaction placed on them, they most certainly Oscillate in their orbit.
They vibrate in fixed orbits, which at times become altered or erratic due to influences.
If it were possible to do so, looking at an Atom would appear more or less like a circular cloud mass, which has an ever changing "Ant Races" like effect ("Ant Races" refers to what is seen on a TV screen when a "Dead" or unused channel is selected - the static black and white dots you see).
The Kernel would be shrouded by the valences of Electrons.
This is - of course, all theory. If anyone has actually seen an Atom, please take pictures of it, post it on-line here at ECN, then describe what is seen.
... [Linked Image] [Linked Image]
It's been nice to go into the "Theory-Theory" stuff again! Been awhile for me!
Scott35
Scott " 35 " Thompson
