hey hey you guys there is the other companine they do make phase conveter also it called ronk conveter i belive if i rember the web address is www.ronk.com but if i did give you wrong one please do let me know i used the ronk they make few diffrent versions of phase converts both satic and rotary version i allready deal both of it it have good and bad each one if need more info let me know i will try to explain more about
merci marc
