Scott already told us that the meter measures only energy (KWH) consumed.
I wouldn't want to be first to disbelieve him.
Tell the utility to put plastic caps over the load side meter plugs and re-install. If the meter doesn't move, there is a short somewhere between the can and the main breaker.
If the meter still moves, tell Scott!
Replacing the service entrance cable is the most likely solution, unless the main breaker is contaminated.
