The flooring contractor could bring a generator and enough cord to do the job.
That is how many cement cutting and coring companies handle this problem.
I really don't even have a problem with the cord above. I do have a problem with the use of alligator clips on the main. Keep in mind that if they blow stuff up it will be your panel that needs replacing.
Bob Badger Construction & Maintenance Electrician Massachusetts
