Ground DOWN, that way if the plug falls out and down, away from the receptacle, chances are the ground pin is still in contact with the inside connections of the receptacle, keeping the ground path intact while the other prongs may be free and clear of the receptacle completely.
The only time I place them ground UP is if its a switched outlet for a table lamp where being "flipped" would kind of indicate that the receptacle serves a different purpose.
Off track, if the receptacle is mounted Horizontal, I always install the receptacle with the ground facing to the left that way the neutral is "UP". Should the plug start falling out the neutral is exposed, and wont pose a great hazard. Yes I know that the same can be said for a vertical receptacle mounted with the ground down,
but the way I see it, with a vertical receptacle mounted ground down, if either one or both halves of the receptacle are used, there is still only the potential of only one "hot" terminal being exposed should the plug(s) start to fall away, and your ground will remain in the receptacle and be "last out". With a horizontal receptacle mounted with the grounds to the right ( hot prongs UP) there is the chance that one or TWO hot prongs could be exposed, depending on the number of plugs in use in the receptacle. Flip it around you have NO hot prongs exposed when and if the plugs start to fall away.
Sorry for rambling on, just thought I'd spit my 2 cents in..
