Sorry all I had forgotten about this thread.
Scott you can certainly use these pictures.
I was supposed to go back last Friday but truck problems side tracked that.
I will be going back soon, they supposedly cleaned the room out. I'll have my camera with me.
Mike that is 3/8" flexible conduit running from a change over fitting from EMT.
Its not flat, I believe it has the low voltage generator start circuit in it.
Pretty sloppy job none the less.
