jbn1611 I'm down in Tullahoma a bit south of you. You might try W&O contruction in Cookeville they build municiple water and sewer plants, they might need some help. If you were around here you could call S&W electrical in Murfreesboro they always need help. They don't pull much romex, mostly all pipe. They're commercial and industrial all the way. They're really pretty nice from the guys I've met, some good lead men, and some real butts, You can call Flor-Daniel they do a bunch of work around here too. Bridgestone in McMinnville always needs some engineering techs, takes a good test score to get in but it's fair money. Crossville isn't that big a town, so you might have to travel to live there and stay busy.
I work in a 45 mile radius of Tullahoma about 5 counties to stay as busy as I want to be. But you make alot of contacts that way. Residential is really hot down here, and you can pull all the romex you want. You've got to be quick to make any money, and the heat is murder here now, but Ain't nobody going hungry. There is some commercial going up and a spec industrial building every now and then. They keep adding on the Nissan engine plant in Decherd TN 12 miles east. It's a lot of rigid pipe there,
Send me an email at GaryKidd@webtv.net and ill see if I can get some phone numbers for you.
[This message has been edited by joeh20 (edited 08-06-2002).]
