To give you guys an update, I knew there would be trouble when three guys were waiting for me when I showed up. Two of which did not speak English. Reading between the lines, I don't belive the contractor did this job, but the other two guys did and I mentions that you must supervised the the work if you are not present. I would not want this on my house, would you? The red tag stands until it is moved over.
