"Green Neutral Ground Wire"??
As far as I know.. You're no longer allowed to use a 3 wire power cord for dryers or ranges... 4 wire is required with separate ground & neutral conductors...
The 1st pic with the 3 wire cord shows the appliance ground bonded to the appliance...
2nd pic shows the appliance ground wire bonded to neutral instead of with the grounding conductor...
-Randy
