A little off topic, but. The company that I worked for was moving a plating machine to Indonesia. Over there virgin PVC is very expensive. It has to be imported from Singapore. So they mainly use used PVC. If it is only used once then it is first generation PVC. If it has been used twice then it is second genration. Then of course there is third generation PVC. You can guess how many times that has been used. Scott
