Happi-
In Eastern Ohio, they used to but Ohio edison hasnt done that in about 10 years, But, anything 400 amps and up they supply, for a nominal deregulation charge. In fact they now charge for everything, 200 dollars for a revamp reconnect, and thats if its on a 3-day basis, they used to put poles in for a service relocation, not anymore those are 1500 dollars a pole.
Any work outside the Norm call and check with your local power provider otherwise you could get stuck with a huge bill .
The de-regulation horror stories are just beginning to come it. This will get worse before it will get better for sure.
-Mark-
